http://www.vwwatercooled.org.au/foru...tml#post497505
Printable View
Good work Dylan.. Only thing is do people read the stickies?
Car: Bora V6 4Motion
Front: 18x7.5 et28 (after 10mm spacer) 225/40/18
Rear: 18x7.5 et18 (after 20mm spacer) 235/40/18
Arch height to ground Front: 23.6"
Arch height to ground Rear: 24.8"
Fenders Rolled: Light rolling in the front
Fenders Pulled: No
Camber: Front No / 1deg extra in rear
http://www.vwwatercooled.com.au/foru...IMG_0818-2.jpg
http://www.vwwatercooled.com.au/foru...DSC_0403-1.jpg
Keep them coming guys and girls.
Learnt something new over the w.e
there is a difference in drive shafts between models. trickysimon's 4mo bora has smaller dia and solid drive shafts, where as mine has hollow and larger diameter driveshafts, this means he has more room to lower the car before having issues with it coming in contact with the chassis. This could explain why some cars manage to get a 50mm drop on a stock sway bar, where as others struggle even at 30mm... Ill do some more research and add this to the first few pages
Sounds like you are looking for excuses for me being lower than you are :P
loving the white on white!
