Wheel whores, advice please
mk4 gti
will rears 19x9 et37 and fronts 19x8 et37 work?
Mine: Octavia vRS Combi (MY15) | Brilliant Silver | 6MT | 162Kw 350Nm | Tech Pack* | 18" Black Pack | Leather | Sky Port | Ordered Aug 14 | Built Wk 48 2014 | Landed 3/2/2015 | Delivered 20/2/2015
Hers: MY06 MkV Golf TDI 6DSG | Silver | Stock | RNS510 + Badge RVC Installed.
Weekender/Project: Classic Mini 1972 Dependant #2: Mk4 2001 GTi
Car: Bora V5 FWD
Front: 18x8.5 ET20 (after 15mm spacer) 205/40/18 Nangkang NS2
Rear: 18x9.5 ET30 (after 10mm spacer) 215/40/18 Bridgestone MY02
Arch height to ground Front: 24"
Arch height to ground Rear: 24"
Fenders Rolled: Front only
Fenders Pulled: No
Camber: -2 degrees in the front from R32 control arms and hubs. -3 degrees in the rear from IDF drop plates.
Cheers fellas
I found the wheels im looking at were once on a r32 on here, he was running these at
18x8 et 22 eg 15mm spacers
19x9 et12 eg 25mm spacers
Do the r32's have different specs for wheel mounting than the gti? They were sitting nice and flush on his car.
If this is the case, best location for hubcentric spacers?
Great thread
Superb thread!
Can you keep the lowered on 17's coming please
I'm currently running my Bora on 17's but looking for idea to improve the stance and overall look of the car.
If you could use the template as well that would be great.
