Page 19 of 29 FirstFirst ... 91718192021 ... LastLast
Results 181 to 190 of 283
Thread: VWW Official MKIV Wheel Q&A
  1. #181
    Nov 2013
    Bathurst
    Stock height atm & 225/40 tyre.
    I couldnt find any photos Trickysimon, not sure why :/
  2. #182
    Jan 2013
    Queensland
    Need a little help with some plans for wheels and if it is even possible.
    Finally in a position to consider my dream rims:
    Looking at fitting C63 AMG wheels (or C180/Kompressor) rims to my 4motion Bora.
    Mercedes Wheel Specs:
    Front: 18x8 et45
    Rear: 18x9 et54
    Thinking tyre size of: 215/40/18
    If i run adapters would the offset be too aggressive and protrude from guards?
    Will I run into rubbing issues with strut if lowered 50mm+
    Help is greatly appreciated.
  3. #183
    Quote Originally Posted by Feeine View Post
    Check the list on the first page and go to 18x7.5 section.
    Quote Originally Posted by blake_ View Post
    Front: 18x8 et45
    Rear: 18x9 et54
    8et30 up front and 9et30 out back should be inside the guards but clear struts and what not, could even go a 225/40 on the back to better match the 215/40 up front
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  4. #184
    May 2014
    Northern NSW
    I am starting to consider my options regarding wheels for my Bora 4mo.
    I spotted some 18 x 7.5 47 using Dunlop Direzza 215/40/18 for sale and want to know if this is in the realm of possibility for a MK4?
    I used this website to check... 1010TIRES.COM - Wheel Offset Calculator
    Based on a stock 6.5" wheel width and assuming i am reading it right...
    Inner Clearance: The inside of the wheel to the strut housing: -18mm
    Outer Position: Position of the outside edge of the wheel: +8mm
    Will spacers be needed or are these measurements ok as is?
    I am currently in the middle of replacing my suspension. Not looking for a ground(or guard) scraping ride at all.
    Any other advice would be great
    Last edited by Caffeine; 19-05-2014 at 11:20 PM. Reason: Ninnja edit for spec correction.
  5. #185
    I had 18x8et45 with 225/40 on stock suspension no worries. Lowered it a bit and suddenly no good.
    So lowered I'd start to look at spacers, it may just fit though
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  6. #186
    May 2014
    Northern NSW
    Thanks for the help Dylan
    So for the record, when you say no good, was the clearance problem with inner guard/shock tower related or fouling on the outer guard?
  7. #187
    the inside of the tyre/wheel was hitting on the strut
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  8. #188
    Jan 2013
    Queensland
    Hey guys, yet another one of my MK4 wheel questions...
    Looking at a set of 5x112, 18x8 et45 wheels (Another member has for sale)
    With 20mm adapters, I believe the offset will be et25.
    I've followed the fitment website, but just a bit concerned with any rubbing issues with the car being lowered 50mm+ or any poke issues with that offset? Appreciate anyones ideas who have run this in the past?
  9. #189
    Jul 2012
    I had 7.5" et44 wheels with 30mm adapters - no poke if that helps - filled out the guards ok though. They were 17" not 18" so not sure of rubbing sorry. The 17s never rubbed at all.
    I should put them up on here when I get a chance actually
  10. #190
    Will fill it out as eri said. Should be fine with a 50mm drop, get a 215/40 tyre.
    Quote Originally Posted by eri_12 View Post
    Please do
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
