Results 31 to 40 of 40
Thread: VW GTi 2004 Question
  1. #31
    Apr 2008
    Quote Originally Posted by SashET View Post
    Hi All,
    A bit of an update;
    Auto Windows Open and Close with the Remote Control - COMPLETE.... YAY!
    I'm now working on the Illuminated Needles and Distance to Empty.....
    Hopefully I'll have more info on these soon, then I'll post a complete 'how to'
    Sash
    You got the windows done with VAG-COM?
    The dash work requires VAG-TACHO I believe.
    Nothing to see here...
  2. #32
    Jan 2007
    Hi All,
    A bit of an update;
    Sash
    Speak to graeme86 he has already done his own, mine and a few others as well, and can tell you exactly how to program it.
    Cheers Al
    My Garage
    People are mushy - Paul Hawkins on the merits of where to crash on the Targa Florio
  3. #33
    Jul 2009
    Quote Originally Posted by Manaz View Post
    Nope, I did the windows with a 'Serial' Vag-Com Cable & Software called VDS-pro.
    Sash
  4. #34
    Jul 2009
    Quote Originally Posted by quozl View Post
    Cheers Al
    Will do, thanks for the heads up.
    Sash
  5. #35
    Jul 2009
    Ok, just to put this thread to bed, I have done the mods I wanted to.
    1. Windows Up/Down via FOB - Serial Vag Com Cable (ebay rip-off) & VDS Pro
    2. Distance to Empty - Vag Tacho (USB) cable (ebay rip-off) & Vag Tacho 2.5
    3. Lit Needles & Gauges (all the time, not just when the headlights are turned on) - Vag Tacho (USB) cable (ebay rip-off) & Vag Tacho 2.5
    4. My 4 Digit PIN Code for the Cluster - Vag Tacho (USB) cable (ebay rip-off) & Vag Tacho 2.5. I should now be able to program my own FOB Keys.
    All up, these two cables cost me $55, not a bad way to spend a lazy fitty....
    Anyone in Melb (North/West) want to get some of these mods done, let me know via PM.
    Sash
  6. #36
    Oct 2006
    remember, 03 models onwards this will work on only with vds.
    wil not work on the motometers!
  7. #37
    do the windows go up with just the one press of the remote? cos if that's the case, there are times when you want the windows open a bit in summer when you lock.
    if it's a hold dow thing or press twice that'd be cool, because having to insert the key into the drivers door to auto close all windows when you forget is a little annoying after the novelty wears off. (i only learnt of this standard feature a few days ago!)
  8. #38
    Jul 2009
    Quote Originally Posted by McDub View Post
    You need to hold the unlock button down to open all the windows and hold the lock button down to close all the windows (even the sunroof )
    Sash
  9. #39
    that's wicked! i want that done!
    can you show me how you found out how to do it? is it just somethign you can post here or is it more involved
  10. #40
    Jul 2009
    Its a little involved if you have never played with DOS or a HEX Editor before.
    Nothing a step by step tutorial cant help solve.....
    Let me know if you want help doing it.
    You'll need both cables though and a laptop with seral connection.
    Sash
