Someone stole your catalytic converter? Doubt this would cause the issue.
Timing belts don't get "loose and needs tightening" - I hope your friend is a better friend than he is a mechanic . Timing belts wear out and need replacing (and preferably before they break and then your pistons and valves need replacing). And if they have loosened due to wear, they'd probably slip a tooth or two, and you'd have consistent issues
My intial gut reaction was transmission related - it sounds like the auto gearbox is starting to play up. Burned fluid or metallic bits in it would be a good sign (but may not necessarily be there if it's something loose or a blocked valve or something - I'm not sure if the VW autos use the traditional "bands" and solenoids of older-style automatic transmissions.
I hope you didn't pay too much for a simple transmission drain and refill...
A sudden jump in revs though could be the gearbox changing down a gear, which it may do because it's losing power. Seems unlikely the car would do this in exactly the same spot on the road each time though.
Has the ECU been scanned for error codes that may help indicate the issue?
