The flat fuses in the box on the battery, that bolt in, are called Strip Fuses.
I can tell you that replacing that fuse will probably not fix your problem ! The fuse blew for a reason, unless you have fixed the thing that blew the fuse it will blow again.
The fan could be stuffed, or you have a short on the line.
