Results 1 to 10 of 17
Thread: VW bora wheel fitment
    Sep 2011
    Hi everyone,
    Wondering if any folks on this forum has seen or have chucked these wheels on their mk4 with the following specs too.
    18 XXR 530 GOLD RIMS WHEELS 18x8.75 +35 5x100 5x114.3 CELICA WRX STi | eBay
    Sep 2009
    brisbane
    they look like bbs ch reps, offset and pcd look okay but id also enquire about the centre bore. if they are made for a wrx the centre bore will be different iirc
    Jun 2009
    Melbourne, VIC
    The World's newest photos by RichieMK4Rich - Flickr Hive Mind
    Those are 18x9.75 et20 though. With a bit (or a lot) of money you can make any wheel fit. You'd need a hub ring adapter for these as the centre bore is 73.1.. Also the ones you linked obvs won't sit as flush.
    VW Bora V6 4motion
    Sep 2011
    Thanks for the input. So you reckon et35 will fit and clear the guard and suspension set up? I was also looking at the GTC wheels and apparently they're the same as VMR's. Seems like they don't have any in the pcd i need.
    Any suggestions on wheels? Budget is about 1k.
    Jun 2009
    Melbourne, VIC
    Do you have a FWD Bora or 4motion?
    VW Bora V6 4motion
    depends on the height of the car to if itll work up front or not. might run into issues with the strut being too close and serious rubbing on the inside of the arch on full lock if its too low.
    Sep 2011
    4motion Bora. Im sitting on oem set up atm.
    stock should be fine with some 225/40s
    might poke a bit then up front
    Jun 2009
    Melbourne, VIC
    I've been eyeing these wheels too but not sure if they'll clear my brakes. they should due to the concavity but you can be my guinea pig. =]
    VW Bora V6 4motion
    Sep 2011
    Quote Originally Posted by kapowww View Post
    Hey kapowww I remembered you had some Miro wheels? Were they these ones?
    Volkswagen Jetta IV VR6 24v > Wheels > Aftermarket Alloys > ES#2535848 18" Style 368 Wheels - Set Of 4 - Hyper Silver / Diamond Polished Lip - W368.815111KTF
    Thinking of having them since the CB is right. How were they sitting without the spacers if you have any on?
