Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: VW bora V6 4motion - engine problem
    Jan 2007
    sydney cbd
    Hi everyone,
    new to the forum and new to VW!
    Im having first problem with my Bora V6 and if any body can tell me the problem with the car.
    (difficult to explain but car sounds and feels lumpy around 2000rpm, the engine not revving smooth as previously (even steering feels bumpy around 2000rpm then disappears)- different noise coming from muffler too in lower revs - i think some power has also been lost in acceleration.)
    no engine warning light has come on and the car is still running - no stalling)
    also feels very slightly when driving there is slight urging in engine when driving along about 25oorpm?
    all
    basically feels like a cylinder has gone?
    can anybody help me out?
    thanks,
    simon
    brackie Guest
    Welcome!
    Weclome to our forum! Lots of knowledgeable people here (and some with VAGCOM ) Might save you a lot of time and money.
    Point Cook, Vic
    ud know if u were running on 5 cyls.
    I was the other day when i forgot to put one of my plugs back onto the coil. The car makes a real farty noise instead of the sweet vr6 noise as u try and accelerate. and u lose a LOT of power. Still quicker than a 4cyl tho
    But yeah. where abouts are u? maybe a quick vag-com scan could unearth something.
    FOLLOW US ON FACEBOOK
    Jan 2007
    sydney cbd
    cool! thanks for the welcome!
    what is this vag-com scan?
    yeah tim does have that 'farty noise instead of smooth pur'
    im located inner sydney
    Point Cook, Vic
    its a small device that allows you to read fault codes from the cars computer.
    If its making that noise id check all of your leads are seated nicely on the coilpack.
    i once also got a similar thing with my car when i had a cracked lead. and the spark was escaping and arcing onto the cylinder head. If u rev the car in the dark any sparks that are leaking should show up.
    Apr 2006
    VW Race HQ - Sydney
    late VR6's run coilpacks
    It'd be a good idea to put your location in with your name so we may be able to direct you to someone locally who might be able to help.
    vag-com can be read about on www.ross-tech.com
    I am thinking not a coilpack as it isn't throwing a checklight on.
    Peregian Beach
    Quote Originally Posted by sim2002
    Hi everyone,
    all
    thanks,
    simon
    I had a problem with the MAF (air fow sensor) on mine. It would play up especially when cold. It would miss and generally run below par but was OK under full acceleration when warm. The people in the know tell me that if you disconnect the MAF and the car runs better then its a fairly sure sign that it is buggered.
    It took the local VW stealer about 3 visits and quite a few dollars, new temp sensor (no difference), new spark plugs (the same) and eventually diagnosed it as the MAF.
    BTW they tried to charge $850.00 for a new one but luckily at the time I had a friend in the UK who e-mailed me a parts quote from Breeze VW that worked out to around AU$250.00. They do them exchange over there and would refund you around AU$50.00 off the $250.00 if you give them the old one. When confronted with that the dealer replaced it for $330.00!!!
    Don't know if this will help.
    Tony
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by h100vw
    Most of the single coil pack cars with DBW have fault codes for coil pack misfires
    Quote Originally Posted by Bug_racer
    With or without getting a check Seb?
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  2. 2.0 Tdi Oil
    By TDI DSG in forum Fuels and Lubricants
    Last Post: 02-01-2008, 08:37 AM
  3. Prob with my '96 VR6 - please help!
    By gman in forum Mk3 Golf & Vento
    Last Post: 02-01-2007, 11:19 AM
  4. Starting up problem...again
    By SOHC in forum Mk3 Golf & Vento
    Last Post: 23-11-2006, 10:48 AM
