Results 1 to 7 of 7
Thread: VW bora not turning on
    Oct 2009
    ACT
    My car hasn't really been used for the last couple of months, turning on the engine once n awhile to keep it going. This morning the car is dead, doesn't even turn on. Possible problems?
    Flat battery?
    What do you mean by not turning on??????????? Does the starter motor turn the engine? Do you get lights on the dash? Give us a bit more to work with.
    Oct 2009
    ACT
    Flat battery?
    No lights on the dash or anything, dead.
    Quote Originally Posted by florantonio View Post
    Flat battery, you could jump start it but don't just connect the leads and crank it. Connect them and leave the donor car idling for ten minutes.
    Otherwise take the battery out and charge it.
    Worst case, you'll need a new battery.
    Aug 2011
    melbourne
    as Gavin said. batteries left to go completely flat can somewhat die. allow some charge to transfer.
    if it kicks over take the car for a good long drive, otherwise it won't charge up sitting idle. then when you are parked disconnect the battery to avoid the leakage.
    iv let it get that low that nothing responds (lights, starter motor etc), new battery or a good jump start and let it run for a extended time.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Apr 2008
    Standard lead-acid batteries dislike deep discharges. Probably time for a new one.
    Nothing to see here...
