Flat battery?
What do you mean by not turning on??????????? Does the starter motor turn the engine? Do you get lights on the dash? Give us a bit more to work with.
My car hasn't really been used for the last couple of months, turning on the engine once n awhile to keep it going. This morning the car is dead, doesn't even turn on. Possible problems?
Flat battery?
as Gavin said. batteries left to go completely flat can somewhat die. allow some charge to transfer.
if it kicks over take the car for a good long drive, otherwise it won't charge up sitting idle. then when you are parked disconnect the battery to avoid the leakage.
iv let it get that low that nothing responds (lights, starter motor etc), new battery or a good jump start and let it run for a extended time.
Standard lead-acid batteries dislike deep discharges. Probably time for a new one.
Nothing to see here...
