I ran 0awg to the rear in my golf.
In the rain scuttle area on the drivers side is a plastic cover which takes the loom to the fuse box etc.
I drilled a large enough hole in this for the wire and sealed with silicon.
The line then ran down under the A pillar and along the side of to the boot area. There is a fairly large cabling area all the way along. Just pop off the trim and pull back the carpet and sound deadning and you will see there is a lot of room.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
There's also a grommet to the left of the abs pump, enters behind glove box next to some sort of climate control pipe. 0awg fits snug.
Pics
Driver's side
Passenger side
The boot
Here is an album with lots of pics of my project.
CarPuter Photos by justcruisn | Photobucket
MK4 GTI - Sold
Sweet!! Thanks for that!
Sent from my iPhone using Tapatalk 2
Yea thanks good pics
2004 VW Bora v5 Auto
Hairy_mic' custom audio build http://www.vwwatercooled.com.au/foru...ent-85117.html
what are the existing holes like in the rear shelf?
Why 16x9's? you already have subs for the low freq, normal 6" drivers should be fine either way. Personally I'd box them below the shelf but depends on the shelf openings.
If you want tight bass, make sure your internal volumes of the sub enclosures match the driver, otherwise you get some notes loud and others soft. I would not be porting the sub enclosures unless the ports match the box and driver spec's.
And thats how the Off Side Sub OSSUB stayed for 8 months,
Been busy over the last few months stripping down OSSUB to remove port hole and improve the fit of the sub.
At the same time i made a start on the NSSUB Using what i have learned from the first attempt at OSSUB
points being :
1 Use only top quality (i used 3m) painters tape. It is low tack. this makes the removal of the mould easy, but because it has a waxy coating on it, it makes the removal of the tape from the backside of the sub easy also (i sprayed oil onto the tape on the OSSUB first timer round )
2 1 thickness of woven glass and 1 thickness of cut glass is sufficient to remove the sub from car and it will be strong enough to hold its shape.
3 the NSSUB is significantly bigger than the OSSUB probably double the volume
Final enclosures are 4 layers of cut glass sandwiched by a single layer of woven
$16 Bunnings 3m Tape
First coat. Woven 1 m2 3% Blue tint added to resin just because
Think this was 3 coats... 1 woven 2 cut
The yellow writing you can see is what is left on back side of sub after tape peels off, Kinda looks cool imho
[/URL]
^ ok so to this point baffle is secured with screws gaps between the baffle and inside of sub filled with Builders bog metal fibreglass any gaps on the outside filled with bog, edges smoothed, and 3 layers of woven glass tying the whole thing together.
Fitted Automotive underlay to the entire inside of the box a few gaps, but considering im doing it all through a 10" hole i think i did ok
Underlay $38 L/m (1800 wide) from Foam and rubber shop
More to come
