Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: VR6 Bora Hesitates on acceleration
  1. #21
    Apr 2011
    Ipswich, QLD
    Well its not that the car has so many issues, its that the misfire is causing more problems with other sensors. The hesitation is going to be spark or fuel related and everything from there is going to affect engine and cam timing etc compounding things and making it feel worse than it really is. Identify the cause of the misfire and most likely all the other problems will automagically go away.
    2003 Bora 4Motion
  2. #22
    Aug 2007
    Just remember this , scanners, even as powerfull as VCDS and even the VW one are only the icing oin the cake mate. They are all too slow. even though VCDS has the turbo mode its still too slow. No faults found doesnt mean no faults. Its just the parameters of all the sensors are somewhat near what the ECU needs to see. Sorry to be long winded but here is an example of what im trying to say - Just had an ABC engined A6 chewing fuel and running crud when warm. No faults on any scanner. Customer complaining of chewing fuel etc. So he is the man driving it everyday and knows when something isnt right. decided to scope the o2 sensors. With the scope connected pulled the brake booster line off to draw loads of secondary aor andthe o2 sensors should have went haywire, but nup, really slow but working so dumb ecu didnt detect any drama. fitted new o2 sensors and fixed, Sorry for the long wind but just trying to say dont totally rely on fault codes or scanners. If it wer me i would smke test the intake and check for secondary air, if its all tight including evap lines then you can rule any of that out, easy test and confirms tight system. The hesitation is due to bad combustion so if the intake is good be checking fule , filter and pressures including flow
    Keep us posted
    Jmac
    Alba European
  3. #23
    Jun 2008
    Cronulla, NSW
    cool - where can one get a smoke test?
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
  4. #24
    Jun 2008
    Cronulla, NSW
    well, I haven't picked her up yet but it appears all it was was a dodgy coil on pot 5 and a TB relaignment. she is apparently all ready to rock and/or roll.
    but to my mind, won't that mean i still have o2 sensor issues from the screen readings on page 2?
