Can I get this kind of information specific to a Bora (VW POLO: 18020 - ENGINE CONTROL MODULE INCORRECTLY CODED) to enable me address P1612?
Vehicle throwing the following codes:
- 17526 Bank1 Sensor 2 Heater circuit, Open circuit (P1118 )
- 18014 Rough road spec engine Torque ABS-ECU, electrical malfunction in circuit (P1606)
- 18020 Engine control module, incorrect coding (P1612)
- 17524 Bank1- Sensor1, Heater circuit, Open circuit (P1631)
- 18039-Accelerator position sensor G79, signal too high (P1631)
- 18088 Reset-resistant limp home (P1680)
I have read extensively on most of these codes and I am still reading.
I know that I have oxygen sensor trouble and that the ECU is most likely burnt - the throttle drivers are burnt.
I know that I need to fix the wiring before installing a new ECU.
What I need which I do not happen to have right now is the detailed workflows for dealing with the above codes.
I do most of my own car repair and so I can perfectly handle these if someone would be kind enough to either share with me the entire factory manual or the parts dealing with the above.
Vehicle in question is a 2004 VW Bora with a 1.6L engine, its a manual with engine code BFQ.
Thanks in anticipation
Tried Ross Tech?
Ross-Tech Wiki
