Very strange.
Maybe its based on power for the car as i dyno'd my car with 50/50, forge 007p, tt, stock and the gfb mach 1 (recirc) and i have major varied results. My dyno results chip only was 104 from memory i think? then slowly jumped up to 128/132 without the k03s and now 144 almost with the k03s.
More so i found that actual boost 'held' more with the GFB Recirc than the others. The forge ones are good however dependant on your springs that your using (3 springs avail) that your boost would come in early or later or drop off earlier or drop off later and was pretty annoying as it wasnt linear all the way through ..
however GIAC chip and oettinger chip ive ran and both times i tried both out and found a 3-6kw which is very minimal but actual driving and PSI held was more noticable for me than anything personally.
my 2psi would be use a bailey's or a forge mach 1 recirc personally. if you want sound get an aem intake or similar as it shoots through the intake and echos.. id be happy if my car made no noise actually.
the only thing i have to pick on the mightmods mk4 is that the k&n pod filter sucking air! suprised how little power it makes for the mods that accompanies the chip.
awesome vid tho .. definitely !
