Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
Thread: VAG-com VCDS tweak list
  1. #41
    Apr 2011
    Berwick, Victoria
    Source: VWVortex
    R32/4mo ESP disable (MK60)
    R32 standard 23049
    21001
    4mo standard 23174
    21126
    VCDS -> Coding -> 07 Login 40168
    Coding 11 -> Enter code above in place of original and "Do it" button
    I used this for my conversion as I didn't have the sensors for ESP
  2. #42
    Jul 2011
    Quote Originally Posted by grtuned View Post
    This question would be hopefully answered by the God of modifications Graham86. On mk4 vehicles with rain sensor is it possible to code for it to close windows and sunroof like mk5 when it begins to rain. Ill also do some
    homework to see if this is a possible adaption.
    I did a little research and found that the rain sensor is independent from any control module it only switches a relay when light from the sensor changes.
  3. #43
    Aug 2013
    Anyone had any experience with VAG Tacho and aftermarket head units? I heard you just need to disconnect the K-Line from the head unit and it should work (which I have done) but the software doesn't detect the cable. When I have the cable plugged into the computer I can also hear a clicking sound from the centre console somewhere. Anyone know if there's something I might be missing here?
    Managed to do the window mod with a vag com cable so I'm not sure what might be stopping me with the VAG tacho one... Was looking forward to setting up distance to empty!
