Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: using a electronic boost controller + chip
    Apr 2008
    Oakleigh, VIC
    wouldn't that be classed a wedgie??
    Only if you're pulling it in the wrong direction.
    Dec 2007
    Melburg East VIC
    you wouldn't hit limp that easy on an agu because it doesn't have a map sensor (that includes all mk4 golf gtis in aust).
    you'd hit limp if you max out your injectors/maf, i've hit limp with k04/no software. just to give an example a k03 on 20psi+ (no software) never put me into limp mode
    there is a guy on tex with APEXI AVCR + k03 chip (upsolute i think), runs a t3 60 and 400-something injectors on an agu engine. reason you dont hear about this on tex that much is because most of their cars are not agu & electronic boost controlers are apparently harder to set up on cars w/map sensors
    1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
    Nov 2006
    Why run one though?
    With a few small mods anda chip you're pushing 20+ PSI anyway.. ?
    Dec 2007
    Melburg East VIC
    not too sure, i guess it allows you to set up boost levels and how it comes on non-dbw cars, whereas on a dbw cars can use v-tune/lemmi....forgot the full name again.
    i can see why that guy would use one, probably to keep boost down as 20psi on t3 would put him into limp, but why not use a mbc? just had a look at apexi avcr specs and you can set up gear specific boost so maybe he went into limp mode only in certain gears and plus from what i remember he had scaled maf & injectors n all sorts of other ****, other than that i don't see much point in it as agu doesn't have boost spikes that could throw you into limp if mani pressure exceeded or does it have surging. i've got a mbc between the n75 valve and wastgate actuator but thats only there to slightly increase the boost.
    Jan 2008
    Melbun
    jarrad mate girls undies are taken off down their legs not over their heads
    2x Caddy, 1x Ducato
