Results 1 to 10 of 10
Thread: Urgent V5/V6 Help Please... Re Camshaft Hall Sensor
    Aug 2011
    Canberra
    Just did the Thermo Fan Resistor Mod (To fix fan low speed) and now I'm having issues with the camshaft sensor...
    I don't think that it's related, as I followed the guide, and there is no link to the camshaft sensor.
    Now, I'm getting a Camshaft Hall Sensor short to ground error on the ECU, and the engine runs like ****.
    00515 - Camshaft Position (Hall) Sensor (G40)
    29-00 - Short to Ground
    It's missing, and backfiring, and running real rough. Idle is rough, doesn't like to rev above 3000, full throttle has no power, 10% throttle accelerates better than full throttle.
    I've disconnected the fans, but no change...
    If I disconnect the sensor, the error changes to Open / Short of the Camshaft Hall Sensor...
    30-00 - Open or Short to Plus
    The car actually runs a little bit better. Less backfiring, more power, better full throttle power.
    There appears to be no short accross any of the pins...
    Multimeter Reading of the sensor
    1 (neg of multimeter) To 2 (pos of multimeter) = Open Circuit
    1 (neg of multimeter) To 3 (pos of multimeter) = 1.4 M Ohms
    2 (neg of multimeter) To 3 (pos of multimeter) = 1 M Ohms
    1 (pos of multimeter) To 2 (neg of multimeter) = 14 M Ohms
    1 (pos of multimeter) To 3 (neg of multimeter) = 11 M Ohms
    2 (pos of multimeter) To 3 (neg of multimeter) = Open Circuit
    Multimeter Reading of the plug
    1 (neg of multimeter) To 2 (pos of multimeter) = 15.8 K Ohms
    1 (neg of multimeter) To 3 (pos of multimeter) = 700 Ohms
    2 (neg of multimeter) To 3 (pos of multimeter) = 2.6 K Ohms
    1 (pos of multimeter) To 2 (neg of multimeter) = Unreadable (Fluctuates between a reading, and open circuit)
    1 (pos of multimeter) To 3 (neg of multimeter) = 700 Ohms
    2 (pos of multimeter) To 3 (neg of multimeter) = 5 K Ohms
    Has anyone had similar issues with the camshaft sensor?
    Are there any other tests that I can perform?
    Is there anyone in the Canberra region that has a spare sensor?? (06A 905 161 A)
    '90 Mk I Cabriolet 1.8L - My toy... err... Daily driver... - Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
    '99 Mk IV Bora V5 <-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
    '05 Volvo T5 S60 - 2.5L Turbo AWD Replaced with '09 Ford LV Focus Sedan <-- Used by the kids
    '07 Eos 2.0 TFSI - Project Eos...
    Jul 2011
    So when you erase the fault it returns??
    Aug 2011
    Canberra
    Yes unfortunately, both codes will return... Grrr...
    Aug 2011
    Canberra
    This looks interesting...
    Car has always felt underpowered, so timing chains out is possible...
    KilometerMagazine.com - 00515 - Camshaft Position (Hall) Sensor (G40): Short to Ground
    Aug 2011
    Canberra
    Thank you guys for your insight...
    Unfortunately, I don't have access to a scope to fully test the sensor, and at this stage, I don't have access to another sensor...
    Seems to be lots of threads about lots of reasons...
    Some good, some bad...
    I'm going to check the cam timing tomorrow (damn that's an annoying job to do on these cars) and hopeully that will eliminate at least one possibility...
    I just hope that I don't need any tripple square drivers to get to the timing cover off...
    Thanks again guys...
    And as always, any other ideas, please let me know... Particilarly 'free' ones to check... lol.
    Aug 2011
    Canberra
    Update:
    I've spent all day on it...
    Looks like it was the camshaft...
    The shorter one (the one with the camshaft sensor) was definately 1 tooth out to the other one...
    I've adjusted it, but managed to break the heater pipe t-piece in the process.
    As I don't have water in it, I haven't started it up yet...
    Will be trying to get a replacement t-piece tomorrow, so hopefully after that she runs properly again then...
    Thanks again guys for your sugestions, and listening to this old man rant... lol.
