Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: URGENT R32 open side vents for R32 part number???
    Dec 2007
    Brisbane, Southside...
    Quote Originally Posted by balkanac View Post
    I lost one of mine and i got them both from VW for $47. First they gave me both open but i wanted the passinger one closed because of the CAI so they ordered a closed one. Better than using a knife IMO
    Wouldn't you want more air being able to get to the CAI?
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Aug 2007
    Perth, Australia
    Quote Originally Posted by Treza360 View Post
    Cheers,
    Trent
    that would get more air in but it can get water in as well. Perth's sewage system is not that good. As soon as it raines you get big puddles that you can't avoid. I can always take it out if i need more air
    1991 BMW 318is RED E30
    Dec 2007
    Alrighty then. That's the good thing about the BMC CDA (as opposed to a pod). Because only the hose hangs down, you'd pretty much have to submerse the thing to get it to suck any water up to the filter and then into engine.
    Cheers,
    Trent
    Apr 2008
    you'd pretty much have to submerse the thing to get it to suck any air up to the filter and then into engine.
    Water, yeah?
    Nothing to see here...
    Dec 2007
    Quote Originally Posted by Manaz View Post
    Water, yeah?
    Wow didn't realise what a long week it's been and how far past my bed time it is...
    Townsvegas QLD
    heres your part #'s cheers J
    Front Lower Grilles:
    Center: 1J0 853 677 F B41
    Left: 1J0 853 665 D B41
    Right: 1J0 853 666 J B41
    Clips for center grille: N 104 910 01
    SLAM.POKE.TUCK.DROP.DOPE!
    Aug 2007
    Perth, Australia
    Cheers,
    Trent
    True but the BMC one was $600+ and mina was $250 and fits perfectly. It looks much better than the BMC too
    Townsvegas QLD
    Cai's are pretty easy to make-I'm sure any place where you live that deals with intercoolers or exhausts can make you 1. Or you can use prebent aluminium piping with some silicone couplers. If your worried about water run the Aem bypass valve. Also you would have to drive through some pretty deep water. The bottem of my filter is 7inchs off the ground and the top 13inches off the ground so for me I would have to drive through water that is deep as the top of the vents on the R bumper. Also when i made my Cai i wanted the filter to be low as possible. Also you can buy different size filters. No sure if that helps at all- and i dont run the bypass with mine. The R has only seen rain a hand full of times. Cheers Jay
