2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
heres your part #'s cheers J
Front Lower Grilles:
Center: 1J0 853 677 F B41
Left: 1J0 853 665 D B41
Right: 1J0 853 666 J B41
Clips for center grille: N 104 910 01
SLAM.POKE.TUCK.DROP.DOPE!
Cai's are pretty easy to make-I'm sure any place where you live that deals with intercoolers or exhausts can make you 1. Or you can use prebent aluminium piping with some silicone couplers. If your worried about water run the Aem bypass valve. Also you would have to drive through some pretty deep water. The bottem of my filter is 7inchs off the ground and the top 13inches off the ground so for me I would have to drive through water that is deep as the top of the vents on the R bumper. Also when i made my Cai i wanted the filter to be low as possible. Also you can buy different size filters. No sure if that helps at all- and i dont run the bypass with mine. The R has only seen rain a hand full of times. Cheers Jay
