Wee bit tasky as there is some hidden things but really not too bad. You have the door card off so you are half way there. remove the grommet in the middle of the door membrane and you will find a plastic rawl plug type set up going through the glass and reg. punch that out. Then remove the bailey channel rubber to expose locking lug. remove the aperture seal and you will expose a screw at the top too. With all of this out you can then grab your window glass and lift out of the door.
Jmac
Alba European
