Results 1 to 10 of 18
Thread: URGENT! Need thoughts and feedback!
    Jan 2012
    Hey everyone, the otherday i was driving home from work when a came to a stop and the car suddenly stalled. It took a few goes and i got it going again but it had no power and seemed to be idling rough. I took it to the mechanics and had the air and petrol filter replaced, the MAF sensor checked and new spark plugs and a tune and it was fine until yesterday it started doing it again. After reading up it seems the car keeps going in and out of 'limp' mode but the mechanics dont know a certain fix. My car is 2001 mk4 vw golf. Has anyone had a similar problem? Any responses or opinions are welcome!
    Much appreciated, Cam.
    Apr 2011
    Check the alternator is charging the battery, if your alternator isn't charging at the car runs only off the battery and the battery cant provide enough charge to run the engine computer etc. It will force it into limp mode.
    By the sounds of your post it probably isnt the alternator, but it happened to a friends car and that was the issue. At the end of the day its another thing crossed off the list of things its not.
    Edit:
    Quick run down if you dont know how. Get a mutimeter from someone and set to Volts DC
    The battery should read 13.5 - 14ish volts while the car is running.
    2003 Vw Bora.
    V6 4-Motion.
    Black.
    Dec 2007
    Girraween
    I dont understand how an alternator can cause this issue. Basics of the alternator is if its not charging the light should come on the dash, if it doesnt the car will run off the battery until it dies then you wont be able to restart the car at all.
    My internet diagnosis is coolant sensor or lambda probe. Its possible it could be the maf as well but Id start with the first two items
    Good luck!
    Euro Revolution - eurorevolution@live.com.au
    Importing Quality Performance and Spare parts for Audi & Watercooled VW's
    New website almost up and running ... http://eurorevolution.webs.com/index.htm
    Courtney
    Jun 2007
    Coil pack! When they crack they get moisture in them and get intermittent starting and running problems. Thats why the problems can be unpredictable. Doesn't have to be rain, just moisture.
    Jun 2009
    Melbourne, VIC
    Did the mechanic have VCDS to check for fault codes? Or do you know anyone who does?
    VW Bora V6 4motion
    Jan 2012
    hey, i will tell the mechanic to change both the coil pack and replace my alternator. Also yes he did have one and when he used it today it said there is a fault with the air intake. So he's going to try and fix that first.
    Dec 2007
    Girraween
    Quote Originally Posted by cam_bourke View Post
    you must have a lot of money to be throwing parts at a car that wont guarantee a fix!
    Courtney
    Jun 2009
    Melbourne, VIC
    Quote Originally Posted by whiteVR6 View Post
    Yeah why would you waste your money replacing that stuff if it's not even proven broken.
    If the fault is with the air intake keep investigating the MAF.
    VW Bora V6 4motion
    Jun 2011
    Coomera QLD
    ok, check exhaust tip....Black sortty?....
    Erskineville, NSW
    coil pack for my mk4 was $350 from VW, $150 aftermarket. Rebuilt alternator would be $300-$400 wouldn't it? Seems a lot of money to be throwing at a more mature car if you aren't sure whether they are broken or not.
    If the mech is replacing parts until it fixes itself then maybe his skillset lies in another marque?
