Check the alternator is charging the battery, if your alternator isn't charging at the car runs only off the battery and the battery cant provide enough charge to run the engine computer etc. It will force it into limp mode.
By the sounds of your post it probably isnt the alternator, but it happened to a friends car and that was the issue. At the end of the day its another thing crossed off the list of things its not.
Edit:
Quick run down if you dont know how. Get a mutimeter from someone and set to Volts DC
The battery should read 13.5 - 14ish volts while the car is running.
