Results 1 to 10 of 14
Thread: urgent help needed
    Aug 2009
    brisbane qld
    urgent help needed
    ok so i need some help i have TA technik coilovers and with the fronts they hit on the inner of my wheels how can i fix this and has any1 else used ta teckniks before...
    Wheels spacers? if so what is the best size for a golf
    Suffolk UK
    Yip, answered your own question, spacers will be the go. Get a wheel on if you can and measure from the outside of the rim to the outside of the arch, thats how much room for spacers you'l have, just take a few mm of so the wheel goes under the arch.
    Pretty sure Tim at Dub Addiction sells em, you'll need longer wheel bolts too
    Aug 2009
    brisbane qld
    ok ill check dub-adiction out bookmarked for good reasons lol. they said the coilovers were to suit mk4 golfs dnt know y i would have this problem and i only have 18x7.5" with original offset
    dub addiction must be down
    what specs are your wheels (offset and i see 7.5 for width)
    I have those coilovers in my bora, are they hitting on the strut or the coils/springs?
    I had big problems with the offset of my wheels (ET45) on a 8" wide rim.
    spacers will be the way to go most likely.
    Aug 2009
    brisbane qld
    pretty sure they are et45 and its hitting on the spring adjustment spindle
    Quote Originally Posted by 83_SUS View Post
    if thats the offset you'll just have to wind them up so the ring is above (or close enough to) the top of the tyre, until you get spacers.
    IMO, spacer size. 15mm will get the rim outside the line of adjustable nut, but tyre bulge can hit... what size tyres have you got? 20mm should make tyres clear even with 225 wide tyres (im guessing thats what you have..)
    Do you have your stock wheels still?
    Aug 2009
    brisbane qld
    yeh still have stock wheels and yeh have 225 wide tires on there how did u know
    im good haha
    Mar 2009
    Southside, South Australia
    im good haha
    or it's the size we all have hehehehe
    Oct 2006
    speak for yourself, 235s and 265s lol.
    with et45 on the wheels u can still do 12mm up front and up to 22mm on rear for spacers.
