Results 1 to 10 of 11
Thread: Upgraded remote
    Jul 2011
    Upgraded remote
    Just want to let people know that an upgrade can be done on remotes so boot function button will operate indivdually via remote control.
    If any one considers upgrade due to faulty remote the may choose this option...
    Jul 2011
    Pic attached
    Aug 2007
    Perth, Australia
    hmmmm, i lost one of my keys, wouldnt mind doing this upgrade
    not sure where to find the new key tho, vw wants $450 for a new one
    1991 BMW 318is RED E30
    Aug 2011
    Canberra
    Getting a replacement key is not too hard...
    http://www.vwwatercooled.org.au/foru...der-61591.html
    The biggest thing is to make sure that the remote you get is of the same frequency and generation as the remote you have.
    Mine has the rounded buttons, and as such is unlikely to work with the remote above.
    I recieved a second remote with the car, but it wasn't coded to the car, nor was it the right blade.
    I bought a blade ($15) off e-bay, got it cut locally at ASI Locksmiths ($20), coded the remote myself ($Free lol), now, I just need to program the immoboliser with VagTacho, which I don't have, nor do I currently have access too...
    '90 Mk I Cabriolet 1.8L - My toy... err... Daily driver... - Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
    '99 Mk IV Bora V5 <-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
    '05 Volvo T5 S60 - 2.5L Turbo AWD Replaced with '09 Ford LV Focus Sedan <-- Used by the kids
    '07 Eos 2.0 TFSI - Project Eos...
    Jul 2011
    My old remote for a Bora looked like the one in the pic but did not have a separate function for the boot. The round type is an accessory central locking module that integrated into the vehicle electrics which was common on golf's made by vortex not sure If you mean that type shadow rusty?, I'm aware the window roll up via remote is possible with this type but not sure about boot opening. I'll post part number if anyone needs it for the remote in the pic.
    Aug 2011
    Canberra
    Whilst your flip key remote has square buttons, mine are rounded... Like this...
    Jul 2011
    Mine was the same as yours. And it worked ok only need to code it, with boot function only the boot will unlock all doors remain locked when you close the boot it automatically locks this where you have to be careful cause if you leave the keys in the boot and close it they will be stuck inside. When I get a chance Ill post the part number of the remote.
    Aug 2007
    Perth WA
    Pretty sure Pierre (fuzion) was selling some of the transponders a while ago but might have run out already.
    '04 BMP MkIV R32 #144
    search getnew
    Aug 2011
    Canberra
    I have a transponder, at least a second hand one, which from what I can tell should work correctly...
    I just need someone with VagTacho Software/Cable, and some time/patience to code it for me...
    Jul 2011
    I'm not 100% sure but it can be done without any need for any computer system, what you need is two keys one in ignition with it on reds then close door and put other key in lock barrel and as you lock key press the remote lock button and visa versa this should code the remote. This could be done on on older golf's but I've never tried it with bora. I'm sure if you search info can be found. I could help you but I'm away till weekend, cheers.
