Results 1 to 10 of 13
Thread: uneven idle v6 4 motion
    May 2010
    bentleigh vic
    For as long as I have owned this car it has always had an uneven idle. About a month a go my friendly vw mechanic told me i needed 2 new O2 sensors,- the car seemed to be running ok at the time so i thought i'd leave it and do some research.
    From what i could discover 8 times out of 10 it was dirty contacts or they just needed to be cleaned or some other sensor was faulty, so it went into the too hard basket.
    Then as I was setting off for Sydney about a week ago I noticed the engine was starting to idle roughly and as the week progressed it just got worse - I should have replaced those sensors,
    This morning i discoverd a vacuum leak in the evap canister line which is hard plastic and has a corrugated section to allow it to bend - right where the corrugations start it was split , with any luck this is probably the reason the computer claimed the O2 sensors faulty. having to deal with unmetered air.
    This engine has so many vacuum lines and sensors it's scary and i think i was extremely lucky to find it, I could have spent Thousands and been no better off. This time it was a piece of duct tape
    So there is a moral to the story CHECK YOUR VACUUM LINES FOR LEAKS
    David
    Mar 2010
    Lesmurdie
    Hmm. You got a picture of this? Mines having the same exact problems, Bad idle, reported oxygen sensor gone....
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Apr 2010
    Sydney,NSW
    What is the exact error you get from the O2 Sensor?
    I have similar problems, idle is sometimes rough and the B1 S2 O2 sensor reports "slow to respond". I replaced the vacuum hose too as mine was split at that flexi section too, didn't make much difference. Need to get around to replacing that sensor at some point.
    Adam
    2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
    Previously -
    2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
    2002 Bora V5
    May 2010
    bentleigh vic
    spot the difference -
    [IMG][/IMG]
    [IMG][/IMG]
    i found it by hearing a slight whistle and then by feel
    I reset the computer to remove all the learned values and now the car has much better acceleration and better fuel economy.
    the 2 o2 sensors identified as faulty - which were not - were the ones before the cat
    Mar 2009
    Sydney boy
    my bora v6 runs crap that hose been replaced MAF sensor been replaced and 1 of the o2 sensors been replaced but the thing is it runs rough only when its been pushed a bit i dont want to keep pouring money into this car if its never ends.
    *its idle is rough when its cold
    *once its warm (90 degs) soon as it gets to 2700rpm theres a surge in power its like iv put my foot down flat when i havnt
    and if you push it some the EPC lights comes on for 1 minute then turns off but the ESP light stays on until you it off and it all resets itself.
    *While the EPC ESP lights are on in idle it just stalls
    would anyone have an idea??
    i dont wanna go to toyota direction
    Apr 2008
    Quote Originally Posted by gringo_54_oval View Post
    Get the car to a specialist (one with VAG-COM or another VW-specific diagnostic tool) for a start. There's too many things it could be to give you a definitive answer over the internet.
    Nothing to see here...
