Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: uneven idle v6 4 motion
    May 2010
    bentleigh vic
    It's the blue tube the corrugation are where the tube makes a right hand turn to go behind the inlet manifold and transfers from chassis to engine
    Maybe your's has already been replaced with a non oriiginal. it dosen't matter I replaced mine with some good quality flexible rubber fuel line.
    Mar 2010
    Lesmurdie
    Ill have a look tommorow thanks though. Just trying to find out if theres anything else that is causing a problem because at the moment mines idling like a drag car which isn't so good.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Nov 2006
    Brisbane Qld
    Another common vac leak is down near the fuel pressure regulator.
    Look at engine manifold on right (passenger) side where the flap mechanism is. You will see the fuel pressure regulator on the fuel rail near there. There is a rubber T- piece in the vacuum line coming off there that can get cracks in it.
    PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
