Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: tyres illegal?
    Why 215/35/18s? Underload rated, undersized.
    You need like a 91, most I know my 215/35/18s are 84 which makes me cringe its so low for our cars
    No point stretching a tyre on a stock fitting wheel, will look stupid.
    I'd be doing a 225/40 or 215/40, but even then 215/40 will be underload rated
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jan 2009
    Quote Originally Posted by dubster99 View Post
    Hey guys so i was a friend at the rim shop on the weekend and the bloke took a look at my tyres and wasnt happy. I bought a set of 18" mk5 r32 reps a year ago and still had tyres on them. Anyways the tyre guy said they are illegal because of load rating? the tyres are 215/35 r18. is he right? He told me to go for 225/40 r18? Thinking i want a stretched tyre so would do you guys reccomend?
    It's not about illegality per se (for instance, it's not illegal to fit 215/35 R18 tyres to a car) but it's about being roadworthy, and hence, safe.
    This is what the rules in SA say:
    The tyres fitted must be suitable for the rim. The tyre retailer should
    have information about matching tyres and rims. Specifications for
    overall tyre diameters are listed in the Tyre and Rim Association of
    Australia Standards Manual.
    The replacement tyres must have a load capacity not less than the
    lowest load rating specified on the tyre placard.
    The speed rating of the tyres fitted to a passenger vehicle must be
    at least 180 km/h ('S') when the tyre placard requires a higher
    speed rating than 'S'
    Source: sa.gov.au - Vehicle standards and modifications
    The tyre fitment with the smallest load index you are permitted to fit on a Golf Mk4 1.6 is 175/80 R14 88H, so you need to fit a tyre with a load index of at least 88 in order for your car to remain roadworthy (though a common option was to fit 195/65 R15 91H tyres from the factory).
    For reference, the Golf Mk4 R32 was fitted with 225/40 R18 88Y tyres on 7.5 J x 18 ET 38 wheels.
    Note that many cars which have properly stretched tyres are probably unroadworthy (tyres too narrow, wheels too wide, or both) which is something you essentially have to be comfortable with if you are into this.
    Also note that if you don't specifically need your car to be roadworthy (e.g. only used for racing, stunt, display or show purposes, or driven on private roads, etc) then you are not required to adhere strictly to the above rules.
