I found the best way to get rid of the chime is to do up my seatbelt...![]()
I read on this forum earlier today that using the VAG-COM you can turn off that annoying seat belt reminder chime, so seeing as I am currently borrowing a cable I thought I would do it.
Found the code and the first two digits were 07 as expected which indicates that washer fluid (01), seat belt (02) and brake pad (04) warnings were active. The theory is that you subtract the number of the option you want to remove, so I subtracted 2 and changed the first two digits to 05, leaving all the rest the same. Clicked the "Do It!" button and all seemed good. I can even exit the software, run it again, load the instruments data and see the code still starts with 05.
But the bloody chime is still there!!![]()
Do I need to do anything else? Tried turning it on and off a few times, even locked and unlocked the car, no change.![]()
Adam
2012 Subaru WRX STi Spec-R in "Lightening Red" because red cars are the fastest!!
Previously -
2007 EOS 2.0 TFSI Indium Grey ~ Photos Here
2002 Bora V5
Nothing to see here...
+1
can i ask is there a valid reason you want to do this?
are you driving at low speeds off public roads, or is it because you are using a 5 point harness on a racetrack or something like that?
if one of the above, and you don't need the normal seatbelt on, just wrap it behind the seat and plug it in.
The chime stops after a few seconds anyway doesn't it?
The seat buckle is hardwired on Australian cars, so you always get the gong for six seconds.
VAGCOM just turns off the emblem in the speedo, you will notice.
The reason I wanted to do this is it really annoys me! I have owned 11 previous cars over the last 20 years and never had one that feels the need to bong at me everytime I turn on the ignition. I don't need to be reminded to put the seatbelt on, it is something I do as a natural reaction after turning the ignition on.
Looks like I will go for the pull-the-plug option instead.
Adam
Previously -
2002 Bora V5
My car does not currently do any seatbelt reminder. So how do I turn in on ? or how do I determine that the feature actually exists ?
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Previously -
2002 Bora V5
+1 just wear your seatbelt.
I may disable it anyway though.
I have to agree, i really hate that thing, I am big enough and ugly enough to know when to put my seatbelt on. dont need an annoying chime to remind me.
Its the first thing to get disabled in every car i own.
currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
