ESP not working is probably going to be a dealbreaker for roadworthy too.
Maybe you could clear the fault codes and see if that stops the light from coming on.
Hey Guys
Today I took my car to get a roadworthy certificate, it failed!
The reason is a faulty ESP sensor turning on the ABS light while driving, Will the ESP button just turn it off and not getting this error?
any idea how to persuade the mechanic that the faulty sensor is not related to ABS and it should pass the test?
P.S: I just bought this car without and have to get a roadworthy certificate to put it in my name.
79 MK1 GLD
03 MK4 GTI
94 993 Carrera
Easy enough to swap out. It's under the dash, you may still need to clear the fault code afterwards though. This link might help.
YouTube
Imlachs or maybe Jollys pick'n'pull. Someone in Melb maybe better off to answer that one...
