Results 1 to 10 of 19
Thread: turbotimer in the gti
    Aug 2007
    doncaster, vic
    has anyone fitted one, i have a apexi tubo timer but doesnt work like a turbo timer should.
    i have to rev the car before i turn the key or else it doesnt work.
    MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
    Mar 2007
    sydney
    Quote Originally Posted by NGOLF.U View Post
    i have hks turbo timer, i dont need to rev the car before turning the key
    Mar 2007
    OK ... I'll admit it ... I have no idea what you guys are talking about. What is a "Turbo timer"?
    Dave
    Mar 2007
    sydney
    Quote Originally Posted by DaveMack View Post
    Dave
    its a timer when you turn the car off and take the key out the car will still run till the timer, which you set for say 1min. it will count down then turn off.
    gpk_gti Guest
    usually a "rice" mod which allows your turbo to cool down after hard driving.
    not for us slow coaches!!!
    Mar 2007
    Ahhh ... that explains the ricies walking away from their still running cars. Now I know. Thankyou ... and George ... who are you calling slow?
    Dave
    Nov 2006
    Definently not a rice mod!!
    The turbo gets VERY hot (Think 500degrees++) and if you just switch off the car after running it hard the turbo remains red hot and the oil/coolant in and around it just cakes itself (solidifies and/or makes itself totally useless).
    Can also put stress on the turbo shaft when you start using it again.
    Turbo timer keeps the car running and allows the turbo to cool down, prolonging engine + turbo life.
    The S3 with the same engine (+ KO4) has an electronic water pump that keeps running well after the car has been turned off. ie - acts in the same way a turbo timer does. If Audi engineers felt the need to include this, it would be advantageous to do similar with a turbo timer - Especially if you car is chipped/modified!!
    gpk_gti Guest
    or if you give it a great hit before you stop the car,which I dont do.the last few k's before home I keep very low revs,which would be the same thing as a idle down.
    car is not insured if something happens whilst turbo timer is active.
    Aug 2007
    doncaster, vic
    ahaha ok... so a turbo timer can work well on a gti?
    i should get mine re installed
    Oct 2006
    From what ive read most turbos now are water cooled as well and the water will still circulate to cool the turbo down after the engine is off (thermal siphon). Only the old oil cooled ones would cook the oil and stuff the bearings. Tho i still agree with what gpk says about taking it easy the last few k's home.
