Results 1 to 10 of 16
Thread: Trip computer questions and problem
    Mar 2010
    Lesmurdie
    Hey all got some questions about the trip computer.
    Whats the reasoning behind the 1 in the corner of the average and all that? Is there a way to get a second set of averages and all that possibly based off the seperate resetable odometer thing.
    Second does anyone know anyreason why my trip computer likes to fade at random times? Most of the time its fine the fist time i drive in the day. Second time, or after a while it starts to fade from the outside in. Lights dont affect it however at night it seems to work perfectly fine. The clock doesnt affect it either.
    Some pictures to help illustrate
    Would replacing it with a second hand one change anything?
    Thanks all.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Aug 2007
    Camden, NSW
    Don't know about the fading thing. But with the number 1 your right, on the bottom of the right stalk there is a button. Push to change between data set 1 and 2, hold to clear that data set. Page 1 clears automatically 2hrs after the ignition isn't turned back on, page 2 will remain until you clear it manually.
    03 MkIV GTI - K04-001, APR 2.5" TBE/TIP/Software, Forge FMIC, GFB DV+, Powergasket+, Dark Tint, 17" Bora Sport, Bilstein shocks, Eibach springs, BMC CDA, Dieselgeek SS, Hella Celis, R32 Alloy Trim...
    95 MkIII VR6 (sold)
    Mar 2010
    Lesmurdie
    Haha knew it. Cheers mate i thought there had to be a way to change it and thought that i tried that but obviously not. Now i can do the fuel economy of each tank
    Aug 2007
    Camden, NSW
    Yep it's great for that, exactly what I do! Cheers
    95 MkIII VR6 (sold)
    Nov 2006
    Brisbane Qld
    Screen fade means the display is on the way out....it is a fairly common fault. It will fade more once the car interior gets hot (after being parking in hot sun for a while). Thats why its okay first thing in the morning and at night time.
    I have seen new display screens on ebay but only for the full size display that fills the whole window. There are a couple of places in Germany and UK that can repair them. Haven't seen anyone here that can do it.
    Mar 2010
    Lesmurdie
    Ah ok cheers. Would i have any chance at finding one at a wreckors? Or would those large ones work? I've seen something on the modification of those large ones to show like radio information and stuff like that but im a bit unsure on that. Like were would the dash indicators go?
    Nov 2006
    Brisbane Qld
    If you swap the dash you also need to match up the immobilizer etc so its not exactly a bolt in.
    The larger display has pixellated warnings that flash up instead of the bulbs in the middle.
    The radio info only comes up if you have a factory euro radio like a Gamma (not the Aussie eurovox stuff)
    You would have to get the larger display cluster from overseas...none were put in Australian cars on Mk ivs
    May 2010
    You probably could get them from a wrecker but personally I'd steer clear of them.
    Most wreckers won't exchange or give you a refund if electrical stuff doesn't work or is doing the same thing as yours.
    Guess it depends how much of a bargain you could pick one up for but be warned.
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
    Mar 2010
    Lesmurdie
    Hmm is it possible to just change the screen then?
    Yeah thats a problem with wreckors but i doubt you can find them new either. This is gonna be fun or just looks like im leaving it.
    Mar 2010
    Lesmurdie
    Today was a wet and dark day and when its dark it seems to be completly fine so im wondering if there is a light sensor that could be effecting it?
