Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Trip computer questions and problem
    Apr 2008
    Quote Originally Posted by Back Door Shenanigans. View Post
    Today was a wet and dark day and when its dark it seems to be completly fine so im wondering if there is a light sensor that could be effecting it?
    I'd bet it was also cold - which goes with what graeme86 said - it's the screen failing, heat just makes it worse.
    If the screen itself can be separated from the dash without critical damage, it should be replaceable.
    Nothing to see here...
    Aug 2007
    Perth WA
    Hi mate, I've had the same thing happen with my screen & agree it occurs when I've been parked in the sun & it's hot inside the car. Once you've been driving for a few minutes and the inside temp drops the screen seems to normalise. Wouldn't worry about it too much.
    '04 BMP MkIV R32 #144
    search getnew
    Nov 2006
    Brisbane Qld
    There is a light sensor near the zero on the speedo which alters the brightness of the display, but on a dark day it would turn the display down
    If you go out when its dark and turn on your ignition then shine a torch on the sensor, you can actually watch the display brightness change.
    Aug 2007
    Perth WA
    Cool you're right Graeme! I'd seen that mark on the dash there but never realised it was a light sensor or the display changed brightness automatically Always thought it was linked to the dash lights
    search getnew
    mines been fading like that since iv owned it.
    It still goes now and as the others say it has to be hot in the car to effect it. Sounded like a lot of trouble to change so i have just left it.
    Graeme i never knew that! Will be trying it next time im in the car at night. Thanks!
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Aug 2007
    Perth WA
    I have a little torch in the car, good fun for a minute haha! Dims and brightens noticeably when you shine it at night
    search getnew
