2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
Hah, yeah they are pretty bad here as well. It is like every section was buiilt on a friday arvo, or something.
Just plain awful.
Thanks for that.
As I said, they are bad here as well.
I actually have Koni coilovers now, and on good roads it is sublime. potholes aren't a problem, because I dodge them.
It is the rough surfaces, where you can't avoid are the ones I expect the suspension to soak up to a degree.
Are your standard Koni struts adjustable externally?
Yeah, I have no intention of taking my R32 to the track.
I am sure it will do fine though, with your suspension, and mine as well. But I drive it everyday, and I want some comfort and compliance.
Thanks for your comments.
Ah, ok.
At the moment I am getting East Coast Suspension to see if they can supply new (softer) springs for my Coilovers. And also raise the height to max height.
Hopefully this works.
If not, will look seriously into the Koni FSD's and or the Bilstein.
Thanks,
Justin
Be careful with your choice with the FSDs. I'm yet to hear anything really good about them. Lots of people I've seen have pulled them out and put normal shocks in.
How high are you at the moment. I'm at 100mm and aside from some occasional sideways driveway entry and exits all is good.
Going back from coilovers to normal shocks just sounds silly I reckon.
The Koni Yellow sports are externally adjustable at the front through the top mounts however the rears have to be dropped out to adjust them.
Cheers,
Trent
Really? I read some good things on low speed comfort damping.
i haven't measured, but its best to measure from centre of wheel to arch.
clearance is fine. just not enough travel to dampen the rough roads, and the spring rate is probably too high.
not silly, maybe not logical, yes.
i drive it everyday, and I want some body compliance and comfort. I am crossing my fingers for these new springs and we will go from there.
Thanks for your help!
Spring rate is the biggest problem I (currently) have with the K-Sports. I'm trying to find out what the stock spring rates are, and may see if I can get some slightly less firm springs made up (the springs have some scrapes and some rust forming on the surface now too).
Nothing to see here...
The hotness....
I've been thinking black front for mine too. Looks great.
2010 Skoda Octavia vRS Wagon
Nice Trent,
I like the black VW and R badges but I need to see it in person to make a final decision on the grill and mirrors but if your going to go the black I think to get it to work you need blacked out wheels as well. There is one on Vortex that has the wheels done as well as your stuff and it looks the ducks nutz.
You could always buy my Superleggeras and powder coat them gunmetal or black Then I could buy 6 new 17" Bora Sports for rallying and have some cash left for the HANS devices
Cheers Al
