Maf has nothing to with the esp.
Maybe you have a bad wheel speed/ABS sensor, or the sensor disc has gunked up.
I had a loose speed sensor once and it made abs kick in all the time, no traction control on that car however.
Just to clarify, i drive an 8L S3 so maybe you mk4 gurus could shed some light on my issue...
the other night I was driving the car home and about halfway into the trip the traction control light decided to turn on; I did not manually press the ESP button at all. Now every time I drive the car, the TC light comes on as soon as I start the car without me pressing the ESP button.
I changed the MAF sensor with a brand new one (as thats what other forums have said to do) and that did not fix my problem. I don't have direct access to a VCDS but could it be that my haldex has finally let go?
I plan on getting it scanned asap but yeah, just trying to figure out possibilities.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
true true, I'll give them a clean and see if that changes anything.
ABS light isn't on so I think it could do with a scan.
Had many an S3 with a bad maf and esp light on at same time,new maf and no esp light.Strange but true.
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
Best find someone with VCDS next and see what the cars says is wrong. ESP and TCS won't work if the ECU can't see what is happening with the engine, ie what the airflow through it is.
Other failures can cause the same lights to come on though, ABS failures, no wheel speed at one corner or the YAW sensor.
Cheers Gavin. Yeah a scan is what I'm going to get done - no more guess work and it'll give a straight answer. Thanks for the input fellas
wheel bolts tight?
Which car fid you do the brake upgrade on?
