An impact gun undoes those nuts best. You might get it with a offset ring spanner. I have a broken ratchet handle with the guts removed and a 22 mm socket welded to it.
Hey,
What tool do i need to take my front coil-overs out i tried just using a socket but the strut just kept spinning, need something so i can get an alan key through the middle to hold it, anybody know what they are called ?
Cheers dude will try and get something sorted tomorrow,
is an impact gun similar to a rattle gun ?
hopefully be able to get it done tomorow night regency on wedensday
A proper offset ring spanner should do the trick..
Yeah
Think i met you at the vw day not long ago ?
im a mate of lorenz
Yeah, that'll be right. If you are struggling and can get to Flaggy you can borrow the ratchet handle tool. Are the nuts 22mm?
Could stick it in my car in the morning, will be on Don Bradman first thing.
Will try and get something tomorrow, have no idea on the size of the nuts might just try get an angled spanner, im all the way up north so would be a fair hike to flaggy, how hard are they to actually change, shouldnt take more than a few hours should it ?
Either an impact/rattle gun to shake it loose, or an offset (60º apparently) ring spanner to turn the nut and an allen key to stop the shaft from spinning.
GAP also have a tool especially for this (http://www.germanautoparts.com/Tools...spension+tools). It's probably the last thing I need to sort out before I try to do my suspension!
Nothing to see here...
