Results 1 to 10 of 11
Thread: Tool Required To Change Coil-Overs
    Aug 2008
    Mawson Lakes SA
    Hey,
    What tool do i need to take my front coil-overs out i tried just using a socket but the strut just kept spinning, need something so i can get an alan key through the middle to hold it, anybody know what they are called ?
    An impact gun undoes those nuts best. You might get it with a offset ring spanner. I have a broken ratchet handle with the guts removed and a 22 mm socket welded to it.
    Aug 2008
    Mawson Lakes SA
    Cheers dude will try and get something sorted tomorrow,
    is an impact gun similar to a rattle gun ?
    hopefully be able to get it done tomorow night regency on wedensday
    Jun 2006
    Orange NSW
    A proper offset ring spanner should do the trick..
    Quote Originally Posted by Vee-Dub View Post
    Regency in Adelaide?
    Aug 2008
    Mawson Lakes SA
    Yeah
    Think i met you at the vw day not long ago ?
    im a mate of lorenz
    Yeah, that'll be right. If you are struggling and can get to Flaggy you can borrow the ratchet handle tool. Are the nuts 22mm?
    Could stick it in my car in the morning, will be on Don Bradman first thing.
    Aug 2008
    Mawson Lakes SA
    Will try and get something tomorrow, have no idea on the size of the nuts might just try get an angled spanner, im all the way up north so would be a fair hike to flaggy, how hard are they to actually change, shouldnt take more than a few hours should it ?
    Should be doable in 2-3 hours with no dramas. If you are changing the shocks you will need something to spread the hub. You could use an allen key that just fits the slot and then twisted.
    I might be going up to Parafield. Check your PM for my number
    Apr 2008
    Either an impact/rattle gun to shake it loose, or an offset (60º apparently) ring spanner to turn the nut and an allen key to stop the shaft from spinning.
    GAP also have a tool especially for this (http://www.germanautoparts.com/Tools...spension+tools). It's probably the last thing I need to sort out before I try to do my suspension!
    Nothing to see here...
