Get the car to someone who can log the codes out of the ECU using VAG-COM or similar, and who is willing to record them/explain them to you. There's a few Melbourne based guys with this capability, I'm sure one of them will speak up soon!
Hi guys, recently just took my gf's golf into a vw specialist around our area (south east melbourne) to get the water pump and timing belt package done. And the specialist has told me that the car would not idle and that throttle body is not responding to basic settings, thus needing another unit. I told him to see if there were 2nd hand TB's around available. He called me back soon after and said that He somehow got the car idling and running by replacing the air mass sensor. So I went to go pick it up and he has advised me its ok to drive untill they come back from xmas holidays in which the TB needs to be replaced.
When I used the search function to check out throttle body issues, a few threads have come up suggesting that owners should have a go at getting the TB cleaned first, but the specialist has advised to me this would be useless.
Im at a loss as to what I should do from here as the circumstance has made me skeptical about the mechanic. I have only bought the car 2 weeks ago with RWC, and have not had issues with idle or response of throttle even untill dropping it off at the specialist. But now the car has come out with me paying an additional $423 for the Air sensor unit alone and flat spot in the throttle.
I'd appreciate any pointers in what actions I should take next or what I should look into
Thanks guys
Nothing to see here...
...or the "specialist" has put the timing belt on one tooth out or something.
i come accross this problem abit with the throttle bodys, go to engine> adaptation> then channel 0, press read then save, this reset the ecu basic settings then you can do an adaptation. this doesnt work 100% of the time but is worth a shot
Thanks for the help guys, will give these things a shot
Merry Xmas
Throttle body adaption sometimes does not give out codes
Sorry I'm a bit lost, does that mean that the TB needs replacement due to its inability to not adapt or is there a chance that it is ok and there is some other procedure that needs to take place to make the TB give a response
Just an update to my previous post, the "flat spot" in the response is no longer present for some reason.
Thanks
