Results 1 to 7 of 7
Thread: throttle body
    Oct 2010
    Wagga , NSW
    throttle body
    Mk 4 golf - sorry forgot to chuck it in the title.
    hey guys ive seen a few threads about this (being that alot of people have had uneven revs and the revs fluctuating) and have checked all the things that you guys have mentioned ( vacuum leaks, also tried to clean out my throttle body) but its still happening.. even got my step dad to look at it and he's a mechanic said its most likely the throttle body itself as my accelerator sometimes feels abit 'sticky' as in wen i accelerate and then release the throttle the car takes a few seconds to realise my foot isnt on the accelerator and the revs are still indicating my foot is on the accelerator then it drops..
    just wandering if anyone else has had the same problem and if so how much would it be to replace the existing throttle body? just a ballpark figure is fine ill have to take it to get a quote again.
    just annoys me as ive had it serviced 2x in the last 3000kms and mentiond it to both mechanics and they seem to tell me there is nothing wrong, when clearly there is.
    cheers
    Aug 2007
    Perth WA
    I haven't had my accelerator stick like you've described but I do get the opposite sometimes, ie when I put my foot on the pedal to accelerate there is sometimes a bit of a surge after a slight delay. My TB has been cleaned out a few times but it does keep faulting, kicks up the revs etc and throws a fault code. I've noticed when it does fault, the air con cuts out too as the TB sensor must get a faulty reading and then the air con compressor shuts off from the ECU.
    I got an approximate price of about $900 some time ago from my mech, so decided I'll just live with it and get it cleaned out & reset every so often. It's a bit annoying coming into summer though when the a/c stops running! You can switch the car off and restart as a temp fix, usually works lol.
    By the way, if a non VW mechanic services the TB, they probably don't perform the necessary reset after it is cleaned out etc. There is a procedure to run through VAGCOM which resets it after a clean/replacement etc.
    '04 BMP MkIV R32 #144
    search getnew
    Aug 2007
    Mk4 Gti New Throttle body is available for $650 from me Brand new FYI.
    Jmac
    Alba European
    Mar 2010
    Lesmurdie
    Quote Originally Posted by geoff_gti View Post
    I didn't think that was super necessary? I cleaned my throttle body out and haven't done that yet. But I was told they adjust themselves as other wise anytime you disconnect your battery you would need to get the throttle body recalibrate.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Oct 2010
    Wagga , NSW
    thanks guys. ill have to see i might just live with it till i get my new engine done n deal with it later or just leave it as the current engine will be in the shed till someone needs one. thanks all the same! is good to know/have some sort of idea about it,
    Aug 2007
    Perth WA
    Quote Originally Posted by Jmac View Post
    Jmac
    Noted!!
    Cheers Jimmy, hope you're back up n running I still gotta sort out my susp. bushes we talked about ages ago too...
    search getnew
    Aug 2007
    Perth WA
    Quote Originally Posted by Back Door Shenanigans. View Post
    Yeah it may only be required when the battery is disconnected, not 100% sure...
    search getnew
