Results 1 to 6 of 6
Thread: Mk. IV rear fog light question
    Dec 2009
    Mt. Colah, NSW
    Hi guys,
    My car has front and rear fog lights, but on the rear only the right side works. I have replaced the bulb to no effect, and on checking the socket it has no power.
    Is this a standard thing with Golfs? Does the Australian model only have one working rear fog light, or is there a damaged wire somewhere?
    Before anyone says "never need them in Australia", I generally agree, but I'm one of those folks that likes everything in my car to work, whether or not I actually use it!
    Apr 2008
    It's fairly common to have only a single rear foglight.
    Nothing to see here...
    Jul 2007
    Brissy
    Yes only 1 fog.
    There is a fairly easy mod to get the other one to work. Also a 5 light break mod turns 2 fogs into break lights.
    Have a look on the 'Tex
    http://forums.vwvortex.com/zerothread?id=1835863
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Dec 2009
    Mt. Colah, NSW
    Awesome, cheers guys.
    If it's not meant to work, then I'm not going to go out of my way to get it going. Just a bit odd that all the wiring and sockets are in place for nothing.
    mine worked straight up, a large number of globes went out so we went on a replacing spree to find i was missing one, put a globe in and it works! i think as you'll see else where that some cars need to be wired up.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Aug 2007
    Perth WA
    Quote Originally Posted by Merlin8r View Post
    The fog light is on the driver's side by default, (ie the side which is closest to the middle of the road) so the wiring would be in place to accomodate both left hand drive or right hand drive markets without needing two different sets of clusters from teh factory.
    '04 BMP MkIV R32 #144
    search getnew
