That's happened to my mk3, I just replaced the thermo fan relay and all sweet![]()
Hi all,
I've got a mk4 golf 1.6 and the thermo fans are on constantly from when I start the car and stay on for 15 mins after the car is turned off. Anyone got any idea's? It keep getting a flat battery lol. Also I've just put in an all aluminum water pump and had yo remove the thermostat cos it was faulty so the car isn't even getting warmsao I got no idea why the thermos are even on :s
Without Your Seatbelt, You Know Your Gonna' Die!
Project: mk1 cabriolet 20vt
I should add mine got water in the relay which caused it to short and blow.
coolant temp sensor has let go.. replace it and all will be sweet
Look into the temp sensor and put a new thermostat back in, it is needed to get the engine up to temp. You will use more fuel until it warms up etc.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
I had this problem on my passat and i thought it was the coolant temp sensor behind the engine but my dash instrument was showing the correct temp
it turned out to be the fan temp/switch which is located at the bottom of the radiator hose, (if your engine is the same set-up as mine)
have a look, if your have it, unplug it, and if your fans go off, thats your problem![]()
