Results 1 to 6 of 6
Thread: Thermo fans staying on
    Oct 2010
    Mildura, Victoria
    Hi all,
    I've got a mk4 golf 1.6 and the thermo fans are on constantly from when I start the car and stay on for 15 mins after the car is turned off. Anyone got any idea's? It keep getting a flat battery lol. Also I've just put in an all aluminum water pump and had yo remove the thermostat cos it was faulty so the car isn't even getting warmsao I got no idea why the thermos are even on :s
    Feb 2010
    That's happened to my mk3, I just replaced the thermo fan relay and all sweet
    Without Your Seatbelt, You Know Your Gonna' Die!
    Project: mk1 cabriolet 20vt
    Feb 2010
    I should add mine got water in the relay which caused it to short and blow.
    Dec 2009
    Albury, NSW
    coolant temp sensor has let go.. replace it and all will be sweet
    Jul 2007
    Brissy
    Look into the temp sensor and put a new thermostat back in, it is needed to get the engine up to temp. You will use more fuel until it warms up etc.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jun 2011
    Parramatta NSW
    I had this problem on my passat and i thought it was the coolant temp sensor behind the engine but my dash instrument was showing the correct temp
    it turned out to be the fan temp/switch which is located at the bottom of the radiator hose, (if your engine is the same set-up as mine)
    have a look, if your have it, unplug it, and if your fans go off, thats your problem
