Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Thermo fans....help!
    Hey All,
    I have been lurking for a few weeks and thought it was about time i joined this community....
    My Bora after years of not missing a beat is playing up and thought that the experts here might be able to assist/recommend a mechanic.
    I need two new thermo fans as mine are shot, also in the need for control arm bushes.
    Any help is appreciated.
    I am located on the Nth Shore of Syd if that is any help.
    4Mo
    Peregian Beach
    Read through this. You may find that your fans are not buggered at all and that just the internal resistor is broken.
    http://www.vwwatercooled.org.au/newf...ead.php?t=4197
    The link to the site that I got the info from is here.
    http://website.lineone.net/~alan.jam...od/Repair.html
    I don't know if this will help you. I did this modification about 9 months ago and so far both the original fans are operating perfectly.
    This site was accessed from the vortex thread here:
    http://uk-mkivs.net/forums/p/59897/488123.aspx#488123
    Last edited by Bora Sport; 17-03-2008 at 04:21 PM. Reason: Added the thread that wasn't there
    Apr 2008
    My fans stopped working as the above. Can I just replace both fans? I don't have the knowledge to make aluminium boards, resistors etc unless someone in Melbourne wants to make a few bucks or slab of beer??
    2000 Mk IV GTI
    Mar 2010
    Lesmurdie
    Quote Originally Posted by dubbed View Post
    You can, But the new one will most likely have the same exact problem. Making up the resistor plate aint exactly hard thought. Just sketch it out onto the plate drill and cut, screw on resistors and join cables
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Aug 2007
    Five Dock, Sydney
    I got mine repairer under the BS used car warranty from the dealer... it was fixed by Barloworld Five Dock for about $1200ish (inc 2xfans + fuses)
    I'll PM you with more details..
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
    Apr 2008
    lol $1,200! Wow...
    Back Door Shen, where can I get the parts locally?
    2000 Mk IV GTI
    Mar 2010
    Lesmurdie
    lol $1,200! Wow...
    Aluminium sheets and nuts and bolts would be from bunnings or metal place i imagine.
    Resistors are here
    Arcol | Passives | Resistors | High Power | Aluminium Housed, Wirewound - 5 to 600W |HS100 1R J
    And cables from what ever your favourite electrics shop is.
    Heres a bit more info if you need it
    http://www.vwwatercooled.org.au/f14/...ora-43843.html
    This fan repair modification was developed for a 2002 model V5 Golf, it will probably be OK for other Golf models especially the V6
    Apr 2008
    Hmm well I am comfortable I can do that sort of thing as long as I have all the correct parts. How many amps is the fuse on top of the battery?
    Just ordered the resistors, now to get the plate made up. The rest should be fairly easy... I'm kind of excited about doing the fix given how much I hate MkIV Golfs now
    2000 Mk IV GTI
    Apr 2008
    Half way through doing this fix. Can someone please clarify the instructions for me?
    I am confused about what to do with the wiring and the in-line fuse(s). What I want to know is, according to the diagram it looks like red/white goes to one resistor, then from the other side of the resistor the new wiring goes through an in-line 30A fuse and then gets 'spliced' into the red/black wiring (you don't physically cut this one). Is that right?
    http://website.lineone.net/~alan.jam...fancircuit.jpg
    2000 Mk IV GTI
    Nov 2006
    Brisbane Qld
    Correct.
    Exactly as per the diagram you linked.
    The red/white wire on the stock fan harness is the low speed circuit supply which runs into the fan motor (which has an internal resistor inside it).
    So you are bypassing the low speed supply going through the original internal resistor and adding your own external resistor.
    PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
