I got my info from FAN PROBLEM - POLL SYNOPSIS - uk-mkivs
And I made this diagram to help some people there understand it a little better...
Each fan has a completely seperate pair of circuits...
They have a 3pin connector. Ground / Low Speed Power / High Speed Power
So it's 1 resistor per fan as both fans have a low speed circuit.
You don't need to cut anything (I didn't). I cut off a small piece of the insulation, and spliced the wires from the resistor between the "Low Speed Power" (red/white wire) and the "High Speed Power" (red/black wire) with a soldering iron...
Dodgy mspaint circuit diagram... You will need to do this for each fan that doesn't work on low speed...
Black = existing wiring
Red = New Wiring / Resistor
Red Dot = Connection Join (I used a soldering iron, but good quality high current crimp on connectors may work)
'90 Mk I Cabriolet 1.8L - My toy... err... Daily driver...- Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
'99 Mk IV Bora V5<-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
'05 Volvo T5 S60 - 2.5L Turbo AWDReplaced with '09 Ford LV Focus Sedan <-- Used by the kids
'07 Eos 2.0 TFSI - Project Eos...
