Results 1 to 3 of 3
Thread: temp sensor sometimes works on mk4 1.6?
    Munno Para West Adelaide
    hey guys wondering if its common problem with the temp sensor failing? cars done 132,000kms? and if its on its way out is it an easy fix?
    cheers
    May 2007
    Jimboomba. QLD
    Yep temp sensor failing is a common fault (especially if it is the early black one). If you are handy mechanically you can do it yourself otherwise it is not a big job.
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
    Mar 2012
    Murrumba Downs
    Just had my coolant sender replaced as it was giving a false reading and preventing the engine from starting when engine was hot. That made the girlfriend happy.
