You probably have a small leak, now that the winter cold is here the coolant shrinks enough to set off the low coolant alarm, then as things warm up the coolant expands above the min mark and the light goes out again.
If the gauge never gets to 90 you probably have thermostat which has stuck open, so max flow all day long never gets very hot.
Gauge should get to 90 in a few minutes of driving and stay there. It is weighted so it will not go past 90 until things get over 105 I believe.
You can spot coolant leaks by looking for a pinkish white powder where the leaked red coolant has dried.
Not sure which car you have but on the GTI there is a plastic junction on the end of the block, battery end which often cracks, or the seal on the temp sensor can leak also. And just about anywhere there is a join you could get a leak.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
