Results 1 to 6 of 6
Thread: In Sydney and need a throttle body alingment
    Oct 2010
    glebe, nsw
    Hi, I just cleaned out my throttle body on a Mk4 1.6l. It Idles a little high (1150) with occasional searching. If anybody out there has vagcom and can help me out that would be awesome. thanks.
    did it idle high before or after you cleaned it?
    If i'm not mistaken, they align themselves after a while anyway? maybe 30 min battery disconnect to reset the ecu does will do it? (prob not, i'm sure someone here will know)
    I've had a throttle body in my car unalligned for about 3 months.
    though saying that, i've got a cable just for this weekend so will perform an alignment on it myself.
    I'd offer to do it if you dropped by tomorrow but it's not my cable plus i don't really know what i'm doing!
    Use the cable Paul if you want. Check out the Ross Tech site for the instructions.
    Oct 2010
    glebe, nsw
    thanks, you guys are awesome. The high idle started afrer i cleaned it seems to ne drinking a healthy amount of fuel. what is your beer of choice?
    thanks for offer, but no need for beer it's a 1 minute job. check your pm
    chris here's your fault codes:
    Saturday,20,November,2010,14:03:07:05691
    6 Faults Found:
    00557 - Pressure Switch; Power Steering (F8
    29-00 - Short to Ground
    00515 - Camshaft Position (Hall) Sensor (G40)
    03-00 - No Signal
    00533 - Idle Speed Regulation
    19-10 - Lower Limit - Intermittent
    00520 - Air Mass / Air Flow Sensor (G70)/(G19)
    31-10 - Open or Short to Ground - Intermittent
    00523 - Intake Air Temp Sensor (G42)
    30-10 - Open or Short to Plus - Intermittent
    00537 - Lambda (Oxygen Sensor) Regulation
    18-10 - Upper Limit - Intermittent
    Readiness: N/A
    the one in bold being the one that re-appeared after they were cleared.
    copy this text and paste into notepad and save file as *.csv
    HTML Code:
    ,Group A:,'010,,,,Group B:,'005,,,,Group C:,'007
    ,,Lambda,Lambda Probe,Activated Charcoal,Lambda Correction,,Engine Speed,Voltage Supply,Coolant,Intake Air,,Throttle Valve,Idling control,Idling control,Operating
    ,TIME,Regulation,Voltage,Valve 1 Duty Cycle,Tank Venting active,TIME,,,Temperature,Temperature,TIME,Angle,learnt value,learnt value,Condition
    Marker,STAMP, %, V, %, %,STAMP, /min, V,°C,°C,STAMP,°,,,
    ,0.97,-8.0,0.63,2.7,0.0,1.99,1888,13.81,94,43,2.60,7.5,1.07,1.00,    1000
    ,3.65,-6.0,0.12,2.7,0.0,4.63,1888,13.81,94,43,5.26,8.0,1.07,1.00,    1000
    ,6.26,-5.0,0.10,2.7,0.0,7.25,1888,13.41,94,43,7.87,7.5,1.07,1.00,    1000
    ,8.82,-8.0,0.59,2.7,0.0,9.87,1888,13.81,94,43,10.54,7.5,1.07,1.00,    1000
    ,11.54,-5.0,0.14,2.7,0.0,12.52,1856,13.81,94,43,13.17,7.5,1.07,1.00,    1000
    ,14.26,-6.0,0.10,2.7,0.0,15.34,1888,13.81,94,43,15.98,8.0,1.07,1.00,    1000
    ,17.03,-8.0,0.72,2.7,0.0,18.10,1856,13.81,95,43,18.71,8.0,1.07,1.00,    1000
    ,19.66,-7.0,0.74,2.7,0.0,20.65,1888,13.91,96,43,21.27,7.5,1.07,1.00,    1000
    ,22.33,-5.0,0.10,2.7,0.0,23.35,1856,13.61,96,43,23.99,7.5,1.07,1.00,    1000
    ,24.93,-6.0,0.10,2.7,0.0,25.88,1792,13.61,96,43,26.51,7.5,1.07,1.00,    1000
    ,27.52,-8.0,0.70,2.7,0.0,28.59,1792,13.71,97,43,29.24,7.5,1.07,1.00,    1000
    ,30.21,-8.0,0.63,2.7,0.0,31.27,1792,13.71,98,43,31.90,7.5,1.07,1.00,    1000
    ,32.99,-6.0,0.10,2.7,0.0,33.96,1792,13.71,98,43,34.57,7.5,1.07,1.00,    1000
    ,35.60,-5.0,0.16,2.7,0.0,36.66,1792,13.71,97,43,37.27,7.5,1.07,1.00,    1000
    ,38.24,-6.0,0.74,2.7,0.0,39.21,1792,13.71,97,43,39.80,7.5,1.07,1.00,    1000
    ,40.77,-5.0,0.18,2.7,0.0,41.84,1792,13.61,96,43,42.52,7.5,1.07,1.00,    1000
    ,43.48,-6.0,0.74,2.7,0.0,44.46,1856,13.30,96,43,45.06,8.0,1.07,1.00,    1000
    ,46.00,-6.0,0.10,2.7,0.0,47.02,1888,13.81,96,43,47.69,7.5,1.07,1.00,    1000
    ,48.75,-6.0,0.08,2.7,0.0,49.83,1856,13.81,95,43,50.49,8.0,1.07,1.00,    1000
    ,51.49,-7.0,0.63,2.7,0.0,52.59,1856,13.81,94,43,53.23,7.5,1.07,1.00,    1000
    ,54.16,-8.0,0.55,2.7,0.0,55.24,1856,13.71,94,43,55.87,7.5,1.07,1.00,    1000
    ,56.84,-6.0,0.12,2.7,0.0,57.79,1824,13.81,94,43,58.40,7.5,1.07,1.00,    1000
    ,59.33,-7.0,0.72,2.7,0.0,61.33,1888,13.81,94,44,61.96,7.5,1.07,1.00,    1000
    ,62.92,-8.0,0.66,2.7,0.0,63.96,1856,13.81,94,44,64.60,7.5,1.07,1.00,    1000
    ,65.63,-7.0,0.64,2.7,0.0,66.66,1856,13.81,95,44,67.34,8.0,1.07,1.00,    1000
    ,68.40,-6.0,0.31,2.7,0.0,69.37,1888,13.81,96,44,69.99,7.5,1.07,1.00,    1000
    ,71.06,-6.0,0.12,2.7,0.0,72.05,1888,13.81,96,44,72.67,8.0,1.07,1.00,    1000
    ,73.67,-6.0,0.14,2.7,0.0,74.66,1792,13.51,96,44,75.27,7.5,1.07,1.00,    1000
    ,76.31,-7.0,0.72,2.7,0.0,77.28,1760,13.61,97,44,77.88,7.5,1.07,1.00,    1000
    ,78.86,-6.0,0.12,2.7,0.0,79.83,1792,13.71,98,44,80.47,7.5,1.07,1.00,    1000
    ,81.46,-5.0,0.12,2.7,0.0,82.47,1792,13.71,98,44,83.10,7.5,1.07,1.00,    1000
    ,84.15,-5.0,0.08,2.7,0.0,85.18,1792,13.51,98,44,85.78,7.5,1.07,1.00,    1000
    hope you can sort it out, sure is idling high!!!
    I thought i logged your maf readout too but seems i didn't
