Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: suspicion that haldex isnt working
    Jan 2007
    Quite often it will throw a code without throwing any indication on the dash, we had this happen at a rally once years ago up here with the resulting Vagcom report something like "brake light switch intermittent". There are a heap of threads on Vortex as dainese says but get someone to scan the car for you with Vagcom if you don't own it yourself or take it to a dealer and get it done it is the only accurate way of knowing what is causing it.
    If you get no codes then some of these threads may help you narrow down the issue.
    Check the following threads on Vortex
    Haldex Problem
    AWD Haldex Issue
    My AWD isn't working
    Haldex Pump Issue
    There are hundreds of others just do a search of the Mk IV R32 forum.
    My Garage
    People are mushy - Paul Hawkins on the merits of where to crash on the Targa Florio
    Nov 2008
    Concord, Sydney
    Quote Originally Posted by quozl View Post
    Well had the car scanned last nite and gave me same code as quozl "brake light switch"... so ill try get it replaced soon and see how it goes from there.
    #33
    Sep 2009
    Brisbane, Queensland
    Look forward to an update - hope that it's no too big an issue.
