given your location mate, i'd give Arthur from Exoticars a call in Nth Parra and swing by there.
Hell, why he is fixing your ride you can gawk at the inevitable Ferrari or Lambo in there too. crazy stuff.
hi all,
a lil background info, mk4 r32 85000km, serviced regularly, blue haldex controller installed and a few other small mods.
now done to the business, after meetin up with dainese on the weekend i have come to the conclusion that my haldex is not functioning properly, as i can get a tremendous amount of wheelspin in 1st and 2nd whilst taking off normally and then accelerating hard.
i have read around a few different places and heard things such as the electric precharge pump being the cause but im really at a loss as to what it may be, so if anyone can provide any comments as to why or what is causing this or have had similar experiences and hopefully solutions, you would officially be my new best friend.
also i havnt had it scanned yet for any fault codes, if anyone can help out with tht would be appreciated.
thanks
Matt
#33
MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
or do what I did and put it on the dyno only to find your driving a 2motion
'03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
in that case for you, was it a fuse or a controller or the diff?
haldex ctlr failed
R32 Fuse List or PDF version
Fuse 31 TCM (Transmission Control Module)
BTW it could be your brake light switch, E brake button or sometimes the plug to the controller gets corroded. Best bet is to scan for codes first.
Quite often it will throw a code without throwing any indication on the dash, we had this happen at a rally once years ago up here with the resulting Vagcom report something like "brake light switch intermittent". There are a heap of threads on Vortex as dainese says but get someone to scan the car for you with Vagcom if you don't own it yourself or take it to a dealer and get it done it is the only accurate way of knowing what is causing it.
If you get no codes then some of these threads may help you narrow down the issue.
Check the following threads on Vortex
Haldex Problem
AWD Haldex Issue
My AWD isn't working
Haldex Pump Issue
There are hundreds of others just do a search of the Mk IV R32 forum.
