Results 1 to 8 of 8
Thread: Suspension replacement on my Golf 99 1.6L
    Apr 2011
    Drummoyne, NSW
    Hi all,
    Just bought the car couple of days ago, and suspension really needs to be replaced. It feels really stiff when driving.
    Any idea on how much are we looking at for replacing the whole front and rear suspension? Any 2nd hand parts available?
    Please give me your inputs...
    Jul 2007
    Brissy
    Strange that you say stiff suspension is bad, mostly soft rubbery no feeling suspension is a bad sign.
    But for a refresh many have opted for the ECS stage 2 refresh kits, it really transforms the front end.
    Factor a bit over $200 landed and a few hundred to have it fitted.
    Home Page > Search > Suspension Refresh > ES#248440 ECS MK4 Golf / Jetta / New Beetle Front Suspension Refresh Kit - Stage 2 - 1J0498010
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jun 2008
    Ringwood, Victoria
    I'd say the car will need shocks also, again, odd that you say it's stiff and needs replacing, like previously, worn suspension generally generates knocks and creaks along with a soggy ride but with lots of kickback through the front end.
    my stock suspension went abit rough in the rear. Was told it was the shocks..
    Apr 2008
    Spring rate controls the rate at which springs compress, dampers control the rate at which the springs expand again. If the springs are too hard, they won't easily compress, and will transfer lots of the road surface irregularity to the chassis. If the dampers have failed, they won't control the rate at which the springs decompress, and the car will "bounce" a lot.
    Getting a good balance between spring and damper rates for the expected usage is a fine art.
    Nothing to see here...
    Jan 2009
    blankedy
    Is the current suspension stock? It may be upgraded, but not to your tastes...
    Best to find out a bit more about whats on there before you get too far... May be good stuff gear but bad bushes, etc.
    stiff usually means sportier... but it might not suit rough roads or comfort. see what's in there because it may be worth more than the stock suspension.
    Oct 2009
    sydney
    I would check whether your suspension isn't actually brand new, it may have just been upgraded, like the rest have said, see how it goes as perhaps your just reaping the benefits of someone elses investment in the car without knowing it.
