Results 1 to 10 of 18
Thread: suspension question....
    Nov 2009
    Newcastle, NSW
    hi all, I'm looking at getting coil overs, ( FK Sport Edition Plus Coil over Suspension Kit) and so dropping the gti about 50 - 55mm. would i need to also get drop links? or a new rear sway bar? I'm running 17 by 8 BBS with et35 ( 12mm spacers on rear) with 225 45 tires
    any advice would be helpful as I'm looking at ordering soon and would like to get all that would be required for these coil overs.
    thanks
    MK4 2003 GTI - GIAC - APR R1 DV - 17 BBS - TT short shift
    42DD 3in DP - AWE 2.5in CATBACK - POWER GASKET+
    ECS LIGHTENED PULLEYS - AFE Pro S Stage 1 Intake
    Aug 2009
    should work fine. when i lowered mine about the same amount i got the drop links but i didnt really need them (used them anyway) - no rubbing or anything lowering that much. not sure if you'd be able to use the spacers still on the rear when lowered. might need to stretch tyres if you do at that height.
    this thread may help. go through there and see if you can find something similar to the setup you'll run!
    VWVortex.com - The Spacers Picture Thread
    Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
    lowering a mk4 40mm or more you are ment to change end links or front sway bar, or if your low enough, remove it. some people have a problem (meee), others dont seem to have the problem. but either way it is a known fact on the mk4 that the sway bar will rub on your drive shafts at a certain drop
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jun 2008
    Ringwood, Victoria
    Will also turn your handling up the preverbial creek with no paddle. You will no longer have proper down travel in your front control arms, you will be flogging out your bushes too....
    Nov 2009
    Newcastle, NSW
    Quote Originally Posted by gavs View Post
    so then if im reading right, def change end links. but also the front sway bar?
    Aug 2007
    Camden, NSW
    You either use new drop links on the stock swaybar OR buy a new swaybar (ie Eibach, H&R, Neuspeed etc) which have extra clearance built in to clear the driveshafts on lowered cars.
    03 MkIV GTI - K04-001, APR 2.5" TBE/TIP/Software, Forge FMIC, GFB DV+, Powergasket+, Dark Tint, 17" Bora Sport, Bilstein shocks, Eibach springs, BMC CDA, Dieselgeek SS, Hella Celis, R32 Alloy Trim...
    95 MkIII VR6 (sold)
    Quote Originally Posted by TazzyVR6 View Post
    pretty much it.
    Be careful with how much certain brand bars let you lower (all are different). I purchased one that cleared the drive shafts, but then it fouled on the control arms all day long. read the fine print on if they have a maximum height drop
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Feb 2007
    I have the very coilovers you've mentioned and have a similar wheel setup (17x8 +32 but with 215/45/17) and so far I've liked them; not too harsh and when you dial up the firmness to around 4 out of 6 all round you get rid of the bouncyness (I hated them on the 2nd setting) and get a much more compliant and nicer ride.
    I'm not too sure how much I've lowered mine, but I have run into swaybar issues (only on the righ hand drive shaft) even after having bought aftermarket and adjustable swaybar endlinks. I just raised it around 10mm and it seemed to remove that problem. I would like to be lower but I am unsure about where to go next after reading about Dylan's issues. My adjustable endlinks are FKs by the way and were around $100 from ECS last year.
    Good luck with the build up and be sure to post some more pictures!
    Mk3.Mk4.Mk1
    My Mk1 Project
    Nov 2009
    Newcastle, NSW
    thanks heaps for the info, thats really helpful. ill be sure to post pics re build as its also going to be full refresh of front suspension and a big brake upgrade 312 vented and slotted discs up front. and am hoping to do it all myself over a weekend. stay tuned !
    Feb 2007
    Good stuff mate, brakes sounds like a good plan.
    Mk3.Mk4.Mk1
    My Mk1 Project
